toedtoes
May 03, 2018Explorer III
SoundGuy wrote:toedtoes wrote:
Small hard-sided (19 - 22ft) - these will give you less room than a hybrid of the same length, but you will not have to deal with tent ends. Most will have a wet bath, but you may find a dry bath. You will usually have a couch or 2-person dinette and a full bed or 4-person dinette. Stovetop and microwave and maybe an oven.
As you are used to tent camping, you are used to having limited water. For fresh water, a 20gal tank will be very similar to how you work now. A 40gal tank will provide you with the ability to use the toilet at night at the minimum. You'll be able to wash your face, brush your teeth and wash cookware. If you're conservative, you will have enough for drinking and cooking.
What are you talking about?! Conventional travel trailers in the 19' to 22' range will have a full bathroom with a separate shower and if it has a dinette instead of a sofa that dinette will almost always seat 4. Mine has 30 gal tanks and we have no restriction whatsoever in using the toilet, shower, washing dishes, or anything else.
I was speaking of the lightweight trailers in that size. If weight isn't an issue, then the OP can get any configuration.
As for water, it is dependent upon your habits, needs, and length of stay. For some, 20gal won't last 2 days. For others it will last a week. My comments were meant as a general guide based on the average user on this forum.
About RV Newbies
