Dutch_12078
Mar 08, 2015Explorer III
path1 wrote:jmccen58 wrote:
In regards to "extend-a-stay" propane set-ups, are Marshall brass products worth the extra $$$ ?
I would of put in one of these "deluxe" models if I'd would of known about them at the time. The "deluxe" model covers about any issue you might have compared to the "regular" one. I don't exactly remember why deluxe is better but it is. Top hole you can run BBQ and bottom hole you can run RV off portable tank. Some people also install a ball cock so propane doesn't spit on you if removing hose under pressure. Other places also have them, but doing it again I would get "deluxe".
http://www.campingworld.com/shopping/item/stay-a-while-deluxe/30340
The only difference between the Extend-A-Stay standard kit and the deluxe kit was the inclusion of the 12' BBQ hose in the deluxe. The hose is readily available as an add on.
www.campingworld.com/shopping/item/12-propane-hose-assembly-with-swivel-ends/24038
About RV Newbies
