SoundGuy wrote:
No kidding! :E All 3 GM 5.3L trucks I've towed with have run a 3.42 axle which itself isn't all that great for towing, I'd much prefer a 3.73 even with my current 2012 Silvy which is equipped with the newer narrow ratio 6-speed transmission. 3.08 for towing anything but a popup is a non-starter IMO. :(
Grit dog wrote:
Then you should just get a bigger truck next time instead of complaining about the poor performance even though you've made the same choice 3x in a row as I read it.
Nope, not a chance when a 1/2 ton Chevy works so well for all other uses. Badgering me doesn't change the fact that a 3.42 axle is only so-so for towing purposes, anything higher (lower numerically) is terrible, and the better choice would be 3.73 or lower (higher numerically). The OP apparently says their truck has 3.08 which is GM's attempt to improve fuel mileage returns in general driving around but it's totally unsuitable for towing.
