curlysue321's avatar
curlysue321
mileage on an rv
Is the mileage on an RV comparable to mileage on a car? I figure most cars are good up until about 100,000 miles before they start having major problems. Hoping to get a used RV with 20,000 miles to avoid the major depreciation when they are new.
  • midnightsadie wrote:
    I have no problem with low miles , siting in a garage well serviced ours only gets about 6k per year ,runs great , we take it out every month and drive it about 15 miles and run the gen set, weather permiting, its all in how it was taken care of . one siting out side poor service I,d stay away from.
    I'd be thrilled to buy a used rig from someone like you!
  • I have no problem with low miles , siting in a garage well serviced ours only gets about 6k per year ,runs great , we take it out every month and drive it about 15 miles and run the gen set, weather permiting, its all in how it was taken care of . one siting out side poor service I,d stay away from.
  • I think Donn summed it up pretty well. There are so many things on a motorhome that can fail due to age. The drive train/chassis, unless it's real high mileage will probably outlast the rest of the rig.
    What year is it? Is 20k divided up thru the years? Such as if its 4 years old and the previous owner only took 5000 mile trips a year, then I wouldn't be afraid of it. Has it sat for a year. Get a professional service job on it and it would be fine with me to take anywhere. Has it sat for more than a year or a season? Ask why and still have the service job on it. The comparison of having a unit 50k with on it is not always good advice with all due respect. At 50k, you have other things to think about like ball joints, brakes, tires ect. If the unit is 10 years old and has 20k on it, it would be a******shoot depending on what it looked like and who had it, Since its used, I wouldn't be concerned with depreciation as that happened when it was driven off the lot when new. Does it need some cleaning and interior repairs like water stains or even carpet stains. With only 20k that would be an issue with me and maybe some insight as to how well it was cared for. Do a car fax.
  • Asking that I assume your referring about motor homes? Mileage really is misleading. A 10 year old MH with 20K miles is going to be a lot worse than a 2 year old MH with 50K miles. Motor homes just do not do well sitting, so low miles on an older one is going to probably need a lot more than a newer one with more miles. Make sense?
