vthoms wrote:
Last year we had planned a trip a weekend apart so I had left some food items in the fridge. There ended up being a thunderstorm which shut off the power to the fridge while it was in my driveway and it all spoiled. I cleaned it and it was mold free for the rest of the summer.
When I opened it this spring, the fridge was absolutely gross. It had lots of mold and mostly in the same places from last summer (the lower shelf in the door and the freezer). It had spread a bit more though.
I have cleaned it again and have the doors propped open to keep the air flowing. But the rubber seal around the freezer is stained and no matter how I scrub it didn't come clean.
I'm using a thyme oil cleaner which is a natural mildew killer.
Why I'm posting is two reasons:
#1. Any suggestions on what type of cleaner I should use to remove the stains in the rubber seal.
#2. What could I keep in the fridge and freezer to keep it from molding up again other than keeping the doors open. Would baking soda work? That's more about smell I thought? A cup of salt?
Thank you
If you had the fridge controls set on AUTO, then it should have switched to lp gas when the power went out. You did have it on AUTO mode right? Wiping the inside of a fridge clean then using clorox wipes will usually take care of any mold problems. Each door should also be cracked open to allow air circulation.
