ken56
Apr 21, 2019Explorer
No one has mentioned a clear 45 degree elbow so I will. Get a clear elbow so you can see when the water runs clear mostly when emptying your black tank and the water flows freely to make sure there isn't a paper clog. Install it at the takeoff and then connect your hose. I don't like to leave anything in my tank between trips because there is no reason NOT to dump when you have full hookup. Use the tank rinser and close the valve to let it fill up again and pull the handle to let it empty. DO NOT leave it unattended, be patient and careful so not to overfill when doing this.
The tank sensors that tell how full they are will be notoriously inaccurate so don't depend on them. Grey tank sensor not so much but the black will get fowled with paper and **** but you will know when its full. Happy camping.
About RV Newbies
