BeerBrewer
Mar 24, 2019Explorer
Beginner Trailer Leveling Questions
Let me start by apologizing for all of the dumb questions that I've been asking.
As the "pick up our new trailer day" nears the number of questions/concerns grows! I was going thru my "still need to buy for the RV" list and came across stuff needed to level the trailer. So I started looking at all of the different ways to level a trailer.
Before I get into what type of leveling blocks to buy etc, I'm wondering how off level most campground campsites are? How high do you typically need to raise the trailer (side to side)? Do I bring enough levers to raise the trailer 4", 5", 6", etc.?? I just don't know. Obviously, when you boondock all bets are off.
What type of leveling blocks do you folks use? I see some use plastic Lego like blocks, some use plastic ramps, some use wooden boards. Is one better than another? Pros and cons? Do the plastic lego like blocks hold up and how many should we carry? I've seen people use wooden boards with and without putting slanted edges or them. Does anyone use the Hopkins kit, where you attach plastic pieces to the wooden boards making it easier to drive up and keep from driving off? Does anyone use the curved levelers made by Andersen and others? These seem interesting, but I was wondering how well they work and what happens if you ride too far and fall off them? How easily does the trailer tires climb these? I can see them acting like skis and sliding me across the campsite.
Does anyone use the electronic leveler like Level Mate Pro, Revo Leveler or Hopkins RV Smart Level? Are these worthwhile investments? I like the fact that the Level Mate Pro has an App that you can use in the truck.
I know that you aren't supposed to lift the trailer with the stabilizer jacks, but I was wondering if there was a limit to how far they should be lowered? I assume that I should buy a some square leveling block to put underneath, but I'm not sure how many to buy. Is one enough or should I figure more?
What happens if we get a flat tire? Should I bring an extra scissor jack or get one the curved gadgets that you put under one tire to lift the other?
Lastly, I'm sorry for all the dumb questions.
Bob
Bob
