Tacswa3's avatar
Tacswa3
Must have items for a new TT owner
As I patiently await the arrival of my new travel trailer this week, I am compiling a list of must have items I will need before heading out on the maiden voyage. This is where I could use everyone's help.
I know I need a sewer hose, white garden hose and wheel chocs but that's about it. What must haves do you recommend for a successful first trip?
  • Before you buy too many things, consider if you really need it, I would love to have the hundreds back we spent on widgets that we never use and just take up space..
  • Get a regular garden hose also and a y with shut offs for the campground water spiggot. If you have a tank rinser on your trailer then you don't want to be hooking up your fresh water hose to the rinser inlet. A short 25 footer should be all thats needed. As for a water presure regulator, I am not so sure they are needed today on the newer units because they are plumbed with PEX pipe. Older units yes.
    On a lot of newer units, it isn't the PEX itself that is the issue, but the connections. Some PEX fittings hold better than others, especially in a high vibration environment. AFAIK, Winnebago uses Flair-It fittings, but the ones in common use are crimps, and if they are not applied 100% properly, high pressure on PEX lines may result in leaks.
    I use a cheapie "high flow" Valterra regulator. It isn't as good as a Watts, but it seems to do the job without issue.
  • My List of...
    ESSENTIALS :
    Bedding (we use sleeping bags), clothes, towels, personal hygiene, laundry bag
    Meals / beverages, silverware, plates, cups, refrigerator bars
    Trash bags, cleaning supplies, rags, broom / vacuum
    Full tank of MY well water with 2ppm chlorine added
    Leveling blocks (lego type, 20), wheel chocks, bubble level graduated in degrees
    Sewer hose, 90deg fitting, universal adapter for sewer system, doughnut ring
    Water hose, cable tv cable, water pressure regulator, 5 micron water filter
    25' 30a ext cord, adapters for 15a and 50a, pedestal electrical tester
    Chlorine source (Calcium Hypochlorite 52% is my choice)
    Tools, flashlight, tire plugs, small air compressor, jumper cables, latex gloves
    Any pet related items... Bowls, leash, tie out, exterior comfy mat
    VERY NICE TO HAVE :
    Folding chairs
    Camp fire materials, cooking grate
    Surge guard, autoformer (both have saved us)
    Interior AC line voltage meter
    Waste water tote (Thetford FX line is awesome)
    Wheel locking chocks
    Gated wye water valve and 25' utility hose / nozzle
    90 deg elbow for city water connection
    LED awning rope light
    Battery operated driver for scissor jacks
    That's all that comes to mind. I mostly limited my list to RV operational items.
  • RJC has a pretty good list. Add to that an emergency kit....Peroxide, bandages, Tylenol, etc. Earplugs if you are going to be camping near people, and alcohol if the earplugs don't work! :B
