ncrowley
May 12, 2017Explorer II
You can get a diesel pusher that can tow an open trailer and put the Jeep and the motorcycle on the trailer. You need to be sure the coach can pull the weight. You can get lightweight aluminum trailer. As already discussed, you an lift the motorcycle and flat tow the jeep if the coach is rated for that weight on the hitch. With a fifth wheel, you would need to get a toy hauler for the motorcycle and then you would use the truck you use to pull the toy hauler to travel in when you get to your destination. You can also double tow but you would need to check state laws to see which states allow it.
About RV Newbies
