bfkhome's avatar
bfkhome
New and Confused
Hello to all. Just bought a used diesel pusher 2003 Itasca Horizon (Winnebago). It seems to be in terrific shape with only 29,000 miles and has been well maintained (or so they said). The dealer proved to be just about useless. Gave me the typical sales pitch and essentially wanted me off the lot as soon as possible so they could move on to the next guy.
But I am fairly mechanically inclined and I felt I could easily figure things out. But immediately (as I drove off into the sunset) I realized I was "in Kansas anymore!" I was in the diesel world and wow is it different from what I know about gasoline engines, maintenance, etc.
I quickly realized that I'd need professional help with maintenance and also that I really really needed to establish a baseline as to where things are right now (oil, transmission fluid, coolant, etc) so that I could start following the manufacturers recommended maintenance (Catepillar engine, freightliner chasis, Allison transmission, ONAN (Cummings) generator).
The BIG problem I'm having is finding people who actually do mechanic work on these type of vehicles. The small-time rv lots will do SOME things like change oil but checking out belts, hoses, spark arrestor on generator, radiator, etc. is proving complicated.
My big question is what do most owners of diesel motor homes do for maintenance? Is there usually a single source or do I have to find a mired of "specialists" for each system on the coach? I immediately figured out that I have a radiator/coolant issue as I'm having to add water each time I take the unit out.
  • Hello, First I would call the dealer and see what kind of reply you get. It should be under some warranty. Camping World, if you have one near by. A good truck repair shop. Either a truck stop or indenpendent shop. Also Stemco does sevicing on class a rv's. Good luck. But don't get taken.
  • Our Foretravel had a Caterpillar engine and, if we weren't near the Foretravel factory for service we relied on truck mechanics. They are expensive. I wouldn't have most RV service centers work on a DP.
