ChiefAndSweetie's avatar
May 17, 2021
New camper towing
Just purchased a 2013 Flagstaff 205 pop-up and would like to tow with my Chevy Traverse that didn’t come with tow pkg. I want to make sure I can tow the pop-up before I get a hitch added. Owners manual says towing capacity is 2000 and camper dry weight is 1900. I’m sure it’s not that simple and was hoping some experienced campers could advise?
Tina
  • JaxDad wrote:
    It’s a pop-up, I don’t see filling the basement storage or FW tanks as being a deal-breaker.
    Put all the camping gear in the Traverse and drive carefully until you can get a frame hitch installed.
    How is that going to relieve the stress on the engine and transmission.
    Heat will be generated and that is what leads to premature failure.
  • On the pop ups the dry weight is just that, shipped from factory. So, you need to add in anything put in at the dealership for weight. So, ac, fridge, water heater , awning, propane tank, battery, and whatever else you have has to be added on to the dry weight. You will be over.
  • JaxDad's avatar
    JaxDad
    Explorer III
  • By the time you are ready to go you will exceed your towing capacity.
    Not a good fit.
