wickedstang03's avatar
Apr 07, 2015
new guy here.... battery chacharging questions
Hello new guy here! Love this forum already.... I just bought my first travel trailer a 2000 prowler 19n and the previous owner installed 2 6v golf cart batteries in series... I have a 1.5watt solar panel would this be enough to keep them charged while its in storage? Or should I get a 5watt panel? And would it need a charge controller? Thanks in advance.
  • RoyB's avatar
    RoyB
    Explorer II
    Basically you need to have almost the same charging system that your 120VAC converter/charger unit gives you if you want to keep up with all of the parasitic drains.
    You can get away with some smaller trickle top-off charge type solar charging if your batteries start out being fully charged but this will go away quicker than you think. If it is stored and unattended for a longer period then you are betting alot of expense on things will be ok when you return later.
    To me it seems like the 100WATT solar charging setup with smart mode controller would serve you best. These solar system are readily available from several sources including AMAZON.
    I have one of those 7 watt solar boards that you sit on the dash behind the windshield that plugs into your always ON 12VDC lighter socket. This is usually in high SUN just a few hours aday. It does great topping off my truck start battery but will start getting behind the charge curve is just a couple of days with all of the truck electronics still active I assume. My saving grace is I very seldom go longer than a couple of days not starting up my truck.
    I count my blessings everyday that we area allowed by the county folks to keep our two trailers parked here at the house where we can keep a watch on things all the time...
    Just a few observations here...
    Roy Ken
  • 1.5 or 5 watts will not keep up with the parasitic draws of the trailer if the batteries are left connected to the trailer. 5 watts will not keep up with the self-discharge rate of the batteries if the batteries are disconnected.
    I'd suggest to get something around at least 100 watts and a charge controller. With that, you'll have something meaningful in the way of solar power. If you check pricing, a 100W module will not be that much more than a 25W module.
  • Welcome to the forums.
    The bare minimum is more like 25 watts with a charge controller. If you wish to be able to equalize the battery bank then 140 watts is the bottom line.
