Godd002's avatar
Godd002
New to RV world...am stressing out.
Hello,
My uncle purchased a class A motor home (1997 beaver) from a friend. My uncle then basically was taken to the hospital from there and didnt come out. So now I have inherited the RV that he had planned on us using. I have no idea how to drive, run, or turn on a RV.
My biggest issue is right now that it is in Florida and I am in Kansas. I know the unit has been sitting with a full tank of diesel and new batteries when needed for the past 4 years but hasnt been driven. i realize i need to get it somewhere to have all the oil and filters changed and an inspection, as well as tires most likely. it also has a leak in the sky light above the shower so i need that area repaired.
So the issue I am running into is that no place locally seems to be able to do all of these issues. some do the engine work, some only the cabin. I think there is a place about 45 miles away that could do it all in one stop.
so my question is, what is the likely hood of a bunch of algae in the fuel and causing problems if i try to drive 45 miles away? Or is it better to take it to a local place that is 10 miles away and get the oil and hopefully fuel taken care of and then go somewhere for the other issues. Since i live so far away i was hoping to fly in and take it somewhere and give them a few weeks and then go back. Any advise on what i should do?
thank you.
  • DrewE's avatar
    DrewE
    Explorer III
    Where was the RV stored? If it's not stored indoors or at least under a roof, I would rather strongly consider either having a consignment place sell it or else sell it yourself locally as-is, where-is. Four years of minimal or no maintenance could very well mean a good bit of water damage to the house structure and a whole lot of work and time and money to get it back into reasonably useful condition.
    If the fuel tank is actually full or very nearly so, the diesel fuel should be okay. It's hard for water to condense in the tank when there's no space for moist air to enter. If it's not full, there could be some water in it and possibly some growth (not technically algae since such plants need light to grow). A mobile RV tech or truck tech might be the easiest way to get things sufficiently well running to safely drive to a repair place; there could be difficulties with the air system, sticking brakes, etc. as well.
  • I'm sure that there are RV repair shops that do house calls in Florida. Hopefully you can find one close. This site a lot of knowledge RVs. Hopefully someone will come by that has local info for you. Good luck.
    The RV location might be helpful.
  • A 30 year old Beaver? Wow. With four year old batteries in an MH that hasn't been driven. Inspect carefully. You may conclude to walk away.
    Add to my profile...1978 Beaver truck camper. Long gone but fondly remembered.
