swanny297's avatar
swanny297
New to TT - TT Tow Weight Question
Hey everyone, I am new to the forum and fairly new to TTs. I bought my truck prior to the thought of purchasing a TT - my wife went camping last weekend with some friends and is fired up about purchasing an RV. We have 2 sons (11/5) and a dog.
I am getting confused with the different weights listed and some of the online calculators, what I want to know is what would be the maximum trailer weight that I can pull (I will add a safety factor as I won't max out my capacity), or maybe someone can give me an "RV Weight for dummies" version. I haven't started looking at TTs and don't plan on buying a new truck anytime soon, I would imagine at least 1 trip a month, probably 2 at the most. I will be using weight distribution/sway control so any advice on those as well would be great. Most of the TT sites I have looked at show an Unloaded Vehicle Weight, Dry Hitch Weight, and some show a GVWR for the trailer. Hopefully I have given enough information about my truck.
My Truck
Ram 1500 Express Special Edition crew cab short box - 5.7 Hemi, 3.55 rear end, 6spd trans, 4x4, tow package, 4/7pin connections, heavy duty transmission cooler. GVWR - 6900lbs, Max payload 1660lbs. Max tow published for truck is 10,350
Thanks
Clint
  • I think your limiting factor will be weight on the hitch, due to its impact on your payload and your hitch weight rating (which you haven't told us). Example: realistically a 7000 lb TT could easily run 1000 lb or more of weight on the hitch, once you load up with water, LP, and everything.
