jrrichar
Jan 23, 2017Explorer
New TT with some questions
Just bought a new ORV Black Rock 20RD (GCWR 6200, full length 24'7, width 8'5). It is still sitting at the dealership due to weather and lack of time to grab it. Went to just sign paperwork as I am traveling extensively for work so won't be able to pick it up until March 1st.
What are the specifics for doing a walkthrough before you take delivery of the trailer?
-Specific points of interest/concern before you take it off the lot?
The tires that come on the TT are 15 inch Goodyear marathon tires (C rated; ST205/75R15 1820 lbs. capacity) and axles rated at 3500 lbs (dual axle trailer).
Would you upgrade to a 16 inch wheel and LT tire (Toyo High Country HD; 2600 lb. capacity) IF you spend a lot of time boon docking and traveling on dirt/gravel single track plus 1000+ mile trips (Pacific NW) at least 3+ times a year. I had 3 major blowouts on a MH and it has left me a bit cautious concerning tires.
Tow vehicle is a 2011 Ford XLT Supercab whose payload (calculated off GAWR which was the limiting factor not the higher payload sticker- thanks to info in this forum) is 1400 lbs. Tires on the truck and suspension just upgraded two years ago. Has tow mirrors, tow haul, and brake controller.
Safety is my primary importance. Would you spend the money on the tire change or would you spend the money on a ProPride hitch? I don't have enough to cover both.
Last question: if you knew you were going to go solar in a year would you buy the batteries configured for solar right away or add to the batteries at a later date? Would you use 4 x 6V or 2 x 12V?
I realize many of these questions are based on personal preference but was just looking for people's opinions on what they consider more significant and why.
Thank you,
Janell
Thank you,
Janell
