Lexinator's avatar
Lexinator
Newbie question
Hey there. Quick question, I am traveling to visit a friend and will be plugging in at their house. Can I use a 30 to 15 amp to plug into their house? Am I only limited to certain things e.g. fridge only no AC? I really was hoping to get AC, but don’t want to cause any issues. Advice needed. This is what I am looking at. 30 Amp Male to 15 Amp Female Dogbone Adapter RV Electrical Converter Cord Cable https://www.amazon.com/dp/B07SSZ8DVZ/ref=cm_sw_r_cp_api_i_4ZZ5EbKPW1PTB
I have a travel trailer. What do you suggest if you were in my situation and needed AC. Thanks!
    Most RVs have 30A Male RV plugs and a 30A Female to 15A Male adapter is used for a household plug. So do you have it backwards?
    You might be able to run a small A/C on a 15A plug but typically not because you have other loads like the refer.
    The typical household circuit has multiple 15A plugs on a single 20A CB. Which means there may be other loads in the house on that circuit.
    The typical household type plug found at campgrounds is a dedicated 20A rated plug. My garage has a dedicated 20A plug - ie a single 20A rated plug on a 20A CB.
    And the situation is more marginal if you need to uses an extension cord due to the additional voltage drop on the cord.
  • 2112's avatar
    2112
    Explorer II
    Get a 15/20 amp male to 30 amp female dog bone (adapter) or puck. Avoid using an extension cord. If you have to use an extension cord, make it as short as possible and either 12AWG or 10 AWG.
    When running the AC, turn off the electric water heater. After running the AC for awhile, feel the dog bone or puck connections. It may get warm, but make sure it's not getting too hot.
  • Your link does not work but NO. You need a 15/20 amp male and a 30 amp female. It"s called a 30/20 dog bone. If your rig trips the the friends GFI circuit you will need to turn OFF you GFI circuit in your rig. A/C may or may not work.
    FYI, AC = 120 volt electric. A/C = Air Conditioning.;)
