lanerd
Apr 10, 2017Explorer II
Johno02 wrote:
And what kind ofoutlet do you expect to have it plugged into??
Exactly!!
Need to know what you are going to plug it into. 50amp, 30amp, 20amp, 15amp????
FWIW, you can get adapters to use your 50amp cord to any of the outlets mentioned above. The gasser will adjust to whatever you use, but be aware that you need a certain amount of amperage to operate certain items or multiple items. The lower the amperage, the less that can be operated. If you just want to keep the batteries charged, 15amps is just fine. If you want to use AC units, 30amps or more is needed. So...
Let us know what you're going to be plugged into and what items on the mh will be operated by that connection.
Ron
About RV Newbies
