doubravsky
Jun 28, 2014Explorer
newbie with new Thor Four Winds Class C- questions?
Just bought a 2015 Thor Four Winds 31W.... out for our maiden voyage, which just happened to be a 3 week 3,000 mile trek. (not optimal but it was that or stick with the pop-up and we were too excited to wait).
I have a couple of questions....
BG- it has a residential fridge (18 cu ft,) and an inverter, and two batteries (I think 12 volt not 6? but not sure). It has an auto gen start feature that I haven't been able to figure out how to turn on.
1) how long should I run generator in evening before shutting it off? I ran it for one hour stopping at 8:00 pm, and the battery status light read full, and turned down the fridge to low, but by 3:00 the inverter read 11. something and was beeping, so I turned it off. Should the fridge draw that much that the batteries won't last through the night while dry camping?
2) the auto levelers are wonderful. But at one campsite it was I guess a little too off- level, and the level got it mostly level, and then said "unable to complete leveling". Should I worry about opening the slide under those conditions? Should I have wooden blocks to place under the leveler jacks to get it close enough to level?
3) under the water pump, both the outside and inside shower seem to have very little water coming out of them. Is that normal and I'm not use to RV showers?
Ok... those are my first most burning questions.... if anyone can help or direct me to a thread that helps... I would much appreciate it!
