time2roll
Jun 24, 2013Nomad
You would only have a transfer switch if you have a built in generator.
120v system in an RV is much the same as at home. It is just a subpanel. Check voltage between the main 30a breaker(Black hot wire) and the neutral bus(common bar connecting White wires). You may need to remove the cover to expose the wires.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
