tenbear
Jun 24, 2013Explorer
justinae wrote:
I reset the breakers in the RV. Nothing changed. The microwave doesn't turn on when plugged in but I would think that 20 amps is enough to run the microwave. It does turn on when I fire up the generator.
To use the generator, do you have to change the plug so that it plugs into the generator? If not, you have a transfer switch which could be bad. Hopefully someone with a transfer switch can give you some hints.
I tried viewing your pics but apparently you have to sign in to your account to view them.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
