pianotuna
Jun 24, 2013Nomad III
Hi Justinae,
I'd suggest the trickle charger. An 8 or 9 hour drive might be enough to get the battery bank up to about 85% state of charge.
justinae wrote:
Hot and neutral are not switched.
I do have one of grandpa's old multimeter's, but it's from the 80s or 90s and not sure I trust it. I have a Klein voltage tester but basically tells me if there is voltage or not.
I don't have to do anything to start the generator except make sure the LPG valve is open then push the start button you see in the photo.
I agree that the batteries might be dead, or at least very low charge. I do have a trickly charger. Should I hook that up or perhaps take a Sunday drive? If I drive to charge the batteries, how long does it usually take?
Thanks again for all the help so far, this is great.
About RV Newbies
