time2roll
Jun 24, 2013Nomad
justinae wrote:
Not using an extension cord. I'm using the cord that came with the RV and a 15/20amp adapter. I have a no contact volt tester that just tells me if it's hot or not and it does read that it's hot.
OK
Plug is hot?
Cord it hot?
Cord entry is hot?
Transfer switch is hot?
Main breaker is hot?
Some place you will need to discover Hot or Not at some connection. The fix the item. You may need to dig a bit.
About RV Newbies
