newcomers wrote:
Ok, another question I hope is OK here. I just took my 5th wheel on it's first maiden trip. I noted a lot of creaking and such while towing. Is this normal? Besides the fifth wheel itself is there anything that needs greasing and lubing besides axles and wheel bearings and that? Also I'm towing with a Chevy 2500 4WD and its a lot of weight on the truck. Should we look at beefing up the rear springs or putting air shocks on the back? I have seen a lot of aftermarket parts for this in the catalogs and it seems like a good idea.
You probably want to start a new thread and ask this. When you ask questions, please give us enough information to help you. We have no idea what year your truck is, the GVWR, the FAWR or the RAWR (front and rear axle weight ratings). Give us the ratings from the label located in the drivers door jamb. If in doubt, more info is always better.
You ask about suspension upgrades. Tell us about the trailer you are towing, the dry weight, pin weight, and GVWR. Better yet would be to take it to CAT scales and tell us the steer axle weight, drive axle weight, trailer axle weight and the gross weight. Remember, we don't know what kind of triler you are towing or the weights. We will try to help but the more info we get the better suggestions we can make. Welcome and good luck.
