wa8yxm
Jan 11, 2016Explorer III
Motor____ (all motor vehicles, Cars, Trucks, RV's Boats, Cycles, Scooters) like to be driven from time to time,, If you are planing on parking it and not moving it for years on end.. Trailer (no motor so much more forgiving of long term parking) That said I'm parked for at least 3 years without moving, but the first thing that will happen after I move this rig is a new engine. (Why I am parked for so long)
Page 2: If you plan on "Seeing the USA in your Chevrolet powered RV" (or Ford, or Dodge, Or Cummins, Or Detroit Diesel, or _____ (Too many to list)____)
Well, A decent size motor home pulling a towed gets about 8 -10 MPG.
A decent size Pickup Pulling a decent size trailer.. About the same.
Same pick up without the trailer, 16-20 MPG
The towed, unhooked from the motor home 30-40 for many today.
Plus the car is easier to park and wiggle through traffic. than the big pickup.
Most of the time you will be driving to events, shows, stores, attractions, church, and restaurants, NOT campground to campground.. Thus the Motor home with towed makes sense.
BUT only if you are going to drive it often enough.
NOTE: if you do as I did the first couple years of motor home ownership (5) And park at home for the winter....
Modify both.. On my motor home is a 30 amp twist lock outlet,, It is in a weatherproof location. (Basement compartment high on the back wall)
On my house was a matching INLET, also weather protected (proper inlet from Lowes or Home Depot)
Inside the house was a professionally installed Generator Transfer Panel
When I came home on New Year's Eve (Baby it's cold outside) I found Frosty the air-blown inflatable snowman sleeping on the job (Was supposed to be inflated) I went to basement, got long cord, pluged outlet on cord onto inlet on hosue and twisted to lock, Uncoiling cord as I walked I walked to the RV and plugged in that end.. On into the RV and get out the Gen-Turi and hook it up, then back inside and push the buttons to start the Generator (parked with full fuel tank by the way) Once transfer happened back to the basement.
Click Lights
CLick Furnace
Click (Several clicks in fact) Fridge, Freezer, More lights, Computers and internet, Television and radio.
Upstairs and turn on a hall light NOT on the transfer panel.. It remained dark.
Hours later, as we sat there in a nice warm, well lit house, the hall light came on.
Back to basement, click everything back to mains Back to Motor home shut down generator, Leave cord for next power fail (Which by the way happened).
Very nice. Turns out I used only about half my generator's output (5500 watt) amazed at how little I needed to be comfortable.
Click Lights
CLick Furnace
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
