dodge guy wrote:
dons2346 wrote:
If you are worried, change the oil before you leave, keep it filled on the trip, and change it when you get home.
Read your owners manual and see what it says. The days of 3,000 mile oil changes went the way of the dodo bird
Sure, and the days of engine issues due to extended oil change intervals is just beginning. See it all the time. 7-12k miles on an oil change will cause issues down the road. Not worth the gamble. I would t recommend going more than 5k miles.
Do you see problems all the time from long oil change intervals or from operation with insufficient oil because the owner wasn't checking the level periodically during those long intervals?
Since this is a fairly recent gas motorhome, the engine is almost certainly the Ford V10, for which there is quite a history already of high mileage engines in commercial operation. Ford's recommended oil change interval is 7500 miles, I believe. If that were too long, you would not be hearing of these engines regularly making 250k + miles without major work or repairs. Going a little over once or twice while doing mostly highway driving (which is comparatively gentle on the oil) is hardly a death sentence for the engine. Driving with insufficient oil, on the other hand, is quite problematic.
For the OP: when I was on a long trip (Vermont to and around Alaska and back), I had my oil changed at a Jiffy Lube in Fairbanks, and that without any trouble or drama. As I recall we sat in the motorhome during the whole proceedings and ate a snack or played a round of cribbage or something of that sort.
