Boon_Docker
May 25, 2019Explorer III
cavie wrote:Boon Docker wrote:way2roll wrote:
One note, open a bath roof vent or something. A by product of LP burning is water vapor and will drive up the humidity in your RV.
No need to open a vent. Running a furnace does not produce water vapor inside the trailer.
Yes it does. We must run a 30 QT dehumidifier with the heater on or watch the water slide down the glass onto the walls. We don't open a vent.
No it doesn't produce water vapor inside the trailer.
If the furnace itself produced water vapor inside the trailer you would die from the CO that it would also be producing.
You have got something else going on that is producing the humidity.
About RV Newbies
