wbwood wrote:
Also don't forget about breakdowns to any of the units that you are purchasing used. Will it need new tires? Will you have a blowout and have to replace a tire or two at a couple hundred bucks a pop? What happens if the a/c quits on you? Or the fridge? What if you do develop a leak? In any of them. What do you do if something happens to the vehicle you are towing with? Maybe you tear up the transmission or the motor blows. There are a lot of what ifs that you can not control. RVing is not done because its cheap. It's a lifestyle.
As far as unknowns, well obviously I'm planning to have plenty of savings still available in case something happened, and I still have my full regular income, so I'm not sinking all my money into this, which is why I wouldn't be stupid enough to go all out and buy some multi-hundred thousand Class A and have no money left.
