2chiefsRus
Apr 29, 2018Explorer
Does your auto gen start also have an option based upon the temperature? Ours has an option where the generator will start if
1 - the batteries are below a level we set
2 - the temperature is higher than we set
3 - the temperature is lower than we set.
2 & 3 were our primary for getting the auto gen start when we had pets. We wanted to be sure in case of a power loss in an rv park that the AC would start up to protect the pets. Maybe there is something similar on yours.
Ours also has a quiet time option where you can designate a range of time where the generator will not come on. That may apply to your situation because if you have the quiet time set to on, then the auto gen start will sometimes kick on ahead of those quiet hours to "prefill" the batteries.
About RV Newbies
