Matt_Colie
Apr 29, 2018Explorer II
sonbeau wrote:
My husband is a seat of the pants type guy but I am very anxious about our first long trip in our new motorhome. There is so much I feel that I don't know about the workings of our coach.
You know most of us were born knowing all about RVing. :B
I keep reading that running the fridge on propane while driving is a no no but can the refer be run off the inverter while traveling?
You should shut it off for fueling and you will have to have the propane shut off at the tank for many tunnels and some other places. Many have been known to blow out while driving, but with most newer (last 20 years) this is not an issue.
We have a 12 cu ft Norcold and a 1000 watt pure sine inverter. If not, what can you do instead of the propane?
Yes, you can, but you have to monitor the house battery to be sure that the isolator is working properly and the charge is being maintained/
Also, we have a Magnum AGS stand alone system with a 5500 gas Onan generator. I think I understand how the AGS is supposed to work and have set the limit at 10.5 volts, but when we enable it, even though we know the batteries are at full charge, the generator comes right on and doesn't shut off. These are my 2 main concerns at this moment and will appreciate any insight from those with more experience.
There are at least two things wrong with the AGS.
The auto-start voltage should be way higher than that. At 10.5 a lead -acid battery has been damaged beyond recovery. That should be set way closer to 12.0 volts.
If the AGS trips when you have a fully charged house bank, it is defective. Get it repaired or find out what its voltage sensing issue really is.
Regardless of what has been written above, reefer fires are not that uncommon. This is one of the reasons that RV insurance is so high. The fires are almost always related to the lack of maintenance of the burner system. It can be just carbon accumulation (often blamed) but it is very often the result of nesting material deposited in the burner assembly by critters. Mice and birds can do this in a day, and either can get in through the tiniest of holes.
Matt
About RV Newbies
