Land_Yachters's avatar
May 28, 2020
Overhead Clearence
So just driving our Tiffin 33 around for first time. It shows 13' height, (which I have not yet verified) but was wondering about the accuracy of clearance signs along the road. If the sign says 13'0", can I trust that?
Didn't see this question posed elsewhere, so thought I would ask.
Thanks
Griff
  • Allworth, good info especially #2. In rural areas roads get repaved over and over and they can be significantly taller than that height sign indicates, which was usually posted back when God's dog was a puppy. Like you, I add 6" to my actual height, yes I measured twice and then once again until I got the same number three times...
    Some places that have tunnels can pose a whole new set of problems, the Blue Ridge Parkway comes to mind. Some of those tunnels are ridiculously low as you get near the right side of the lanes. I see posts just telling folks no problem just stay in the center {over the double yellow} but as a guy who rides motorcycles I take serious offense at that lame advice.
    Bottom line, not every RV can safely transit every road. I just wish more folks would realize that and stick to roads that their rigs and skill levels match. Rant off... for now.
    :B
  • With some warnings, they are fairly accurate. Federal Highway Admin design standards require that they be within 2 inches at time of construction.
    However....
    1. States have uniformly adopted FHWA standards. Cities and Counties are on their own. Nobody deliberately miss-marks a clearance, but some may not be marked at all.
    2. Maintenance agencies tend to leave old signs in place when they repave (except on Interstates) and paving can raise the road surface as much as 1.5", reducing clearance.
    3. 13'- 6" is minimum for federal and state roads without advanced warning signs. Minimum is measured at the closest point between the road surface and the bottom of the overhead structure; usually at the right edge line of the right lane.
    4. Confirm your actual highest point. (RV manufacturers frequently forget air conditioners or sat dishes) Measure with the unit loaded for travel and the air suspension (if equipped) pumped up. My trailer is 12' - 9" over the front AC. I approach anything less than 13' - 3" (six inches clear) with extreme caution. My height in English and Metric units us written in large letters on a card taped to the driver's sun visor.
    A
