Both packets and liquids have their pros and cons. Packets are definitely more convenient and less messy—just toss one in and you’re done. Liquids can be more customizable if you need to adjust the amount based on tank size.
If you’re happy with the liquid you’ve been using, it’s probably working well for you. But if you want something easier to use, packets could be a great switch. It might be worth trying a few different options to see what you like best!
- way2rollOct 10, 2024Trailblazer
Not sure if you're aware but you are responding to a post that's 10 years old.
- 5thwheelbreezyOct 22, 2024Explorer
I appreciate new responses to old threads being new to full time trailer living
- StirCrazyOct 23, 2024Moderator
the only issue is you have to temper the information in that old thread. so much has changed, been proven not a good way to do thing, or the opposit and it is a good way. to me the best way to find info, is to search a topic, read all the old threads then post a new topic of discussion. this engages people that are active on the board and can get you the most uptodate information.
a good example of this is older posts on LiFePO4 batteries.. no one knew exactly what they were or how they worked so we had a lot of myths and downright falsehoods that were being spread about them due to people asuming they were the same as other Li chemistry batteries, which took years to dispell. if you dig up old threads then that puts that thread up front for new people like your self to ready and if you don't know anything about LiFePO4 your going to go away thinking your rv is going to burn down and so on.. personaly I would like to see any thread that has been inactive for 2 years be locked to read only. plus the fact that new topics engage more people and more board activity.
