Muddydogs
Jun 11, 2015Explorer
Mark Heron wrote:
Guess I was looking for a basic list of must haves to set up trailer without going through 10,000 posts and reading how I need cornhole boards and cast iron skillets, my bad!
Here is my basics.
Water hose
Water pressure regulator so you don't blow your trailer lines
15 amp and 50 amp plug ends for your 30 amp trailer plug. If you have a 50 amp service then you need a 30 amp adapter. 15 amp is to hook into extension cord.
Sewer hose
Toilet chemicals
Blocks for stabilizer jacks and tongue jack. If you are on soft ground your tounge jack will post hole into the dirt. Wood works.
Harbor freight fuse assortment sized for your trailer just in case you blow one.
Chock blocks and wheel leveling blocks. Wood works.
Check your propane tanks to make sure they are full.
Charge your batteries because they probably are not full from the dealer.
Other then that throw in some food, cooking gear and your clothes then go have fun. Keep a list of must haves and things you want so you can remember to get them added before next trip.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
