twainharteartisExplorerAug 18, 2013Plug 50 AMP into 30AMPIf you have a Motorhome that is set up with 50 amp and you can only find a camp with 30 AMP can you plug into it? Will it cause a problem with the electrical system>
twainharteartisExplorerAug 19, 2013I thought that 30amp service would run the unit just wanted to make sure Thanks
Related ContentFurrion 30Amp plug kit7 pin plug amperage rating?Replacing 30amp male plug30amp camper plugged into 110 home outletPlugging 30amp plug into inverter to power unit?
