h2guy
Aug 21, 2013Explorer
VintageRacer wrote:
50 amp service gives you two legs of 120 VAC at 50 amps each, so you have the option of 240 VAC if you have a residential stove-top or dryer, and you have access to 100 amps of 120 VAC. 30 amp service is one leg of 120 VAC at 30 amps, so you have less than a third of the possible power. The adaptor will send the 120 VAC to both legs of the 50 amp cord so any 240 VAC appliances will not work. 30 amps is good for one normal RV airconditioner. There is another possible alternative - if there is a 20 amp plug as well as the 30 amp plug you can probably use both, and get up to 50 amps of 120 VAC, but you need to have built in the ability to separate things. There may be an adaptor that you could buy that would let you connect the 20 amp and 30 amp plugs to your 50 amp cord. You still won't get 240 VAC.
Brian
Why is there always a techo babble answer to a simple question.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
