RoyBell wrote:
You can run all that fine off 115 V (not 112). It's the Air Conditioner that is the big load that will trip it. If it doesn't then I would check your breaker box as that entire load would be over 15 amps (most likely what you are plugged into). Fridge, lights, little stuff will be fine.
Sorry, meant 115v, standard three prong plug found in the garage. I have a friend who is an electrician and will have him look at it next time he's over. I wouldn't mind paying for a 220v (or whatever the dryer uses - if that would be better and safer. Thanks.
