bsmith95610
May 31, 2016Explorer
Power Inverter Issues
Hello,
I just bought my first travel trailer a couple of weeks ago and it’s the first camper I’ve ever owned. The trailer is currently wired up to a power inverter that is not currently working. I went ahead and ordered a new 1000 watt power inverter and when I plugged in this power inverter it worked for about a minute then it’s light turned red and the mechanics light that I had plugged into it shut off. If I plug the travel trailer into the house the power inverter works just fine. I’m assuming the deep cycle batteries that are wired in parallel may be the issue but I was wondering how I could test that theory out further. I charged each battery overnight on a trickle charge about a week ago. I touched the leads of the wires with my multimeter and they were at around 11.5 volts and the gauge of wire looks pretty thick to me so I’m assuming that is not the issue. I didn’t know if there was a good way to test out the deep cycle batteries further without buying two new ones. Any help would be much appreciated.
Thanks
Thanks
