jerseyjim wrote:
Leaving tomorrow, I turn my fridge (gas/electric) on tonite. a good 12 hours. Leveling the RV perfectly used to be almost mandatory. Now...with the newer ones, not so much. If you're comfortable when loading the RV for a trip, so is the fridge.
G'luck !
I disagree. No difference between older and newer when it comes to an ammonia thermo-siphon fridge. Must be level within 3 degrees.
Now if you have a compressor fridge (residential or Secop/Danfoss), level is not that critical. within 25-30 degrees of level will suffice.
