- Dick_BExplorerI have one in the bottom of my hose container but prefer to fill the FW tank and use the pump at all times. When the pump comes on in the middle of the night with no demand there might be a leak somewhere. With only campground water no warning until your feet are wet in the morning!
- I NEVER traveled with one.... I ran into a site that had HIGH pressure and it caused a leak in my underbelly..
NOW - I don't leave home without mine . . cost - $ price.less - SchertzExplorerExcellent investment for about $30.00 (with gauge). Have observed many water pressure variations.
- Matt_ColieExplorer IIOur coach is so old it is all copper plumbing. But I carry a regulator because, like Old Guy, I hooked up once and went out to see the potable hose vastly swelled. That became our wash-down hose.
Matt - BumpyroadExplorerI have a water pressure meter that has an arrow that will lock at the maximum pressure the system sees. scary at times.
but don't get the $9.00 walmart special, get a whole house type.
bumpy - old_guyExplorerI pulled into a friends place in Yuma and you should have seen the water coming out of the TT. I turned off the water and got out my regulator and the water only flowed to the sinks and toilet, not out the bottom of the TT. I have also seen my white water hose look like it ate a rabbit. amazon has several adjustable regulators. Valtecs, I think I spelled it right is one of the ones I have
- ROBERTSUNRUSExplorer:) Hi, my trailer has a water pressure regulator built in to my water inlet. I still carry a water pressure regulator to protect my water hose at camp grounds with high pressure. So far, all of the camp grounds with high water pressure let us know in advance. Most of these camp grounds sell or loan you a pressure regulator.
- George_HExplorerThe plumbing in many 10 year old RV's was done with tubing that is only recommended for 45lbs pressure. Later units can handle a little more, a limit to 45 or 55lbs can be considered cheap insurance.
- pianotunaNomad IIIHi,
I had pressure so high at one campground that it destroyed the hose. That was fortunate because it protected the RV. - ksg5000ExplorerYes I have run into high pressure.
I have also witnessed RV's flood out because of plumbing failure while hooked up to campground water (not sure whether it was due to high pressure). If your not around when you have a plumbing failure when hooked up to shore water - yikes.
I do have a water pressure regulator ... but after seeing the RV flood I decided to just use the FW tank ... little pump noise beats fighting the insurance company over a flood issue. Just my 02.
About RV Newbies
4,032 PostsLatest Activity: Aug 28, 2025
