fulltimedaniel
Apr 02, 2017Explorer
DallasSteve wrote:
I've been researching travel trailers and I'm not sure yet whether I want a fifth wheel or a bumper pull trailer. I've read more than once that a fifth wheel is easier to handle/more stable on the road. I've heard others claim there's not much difference if they are set up correctly. Part of my hesitation on going with a fifth wheel is losing the truck bed, the additional tow capacity needed, the additional height, the additional cost. But they are nice. And I will probably put several thousand miles per year on it so doing that with more tranquility would be nice.
Can some of you who have pulled large trailers (over 35 feet) of both varieties give me your opinion about the difference in feel on the road?
(Moderator, if this would be better under General RV or somewhere else feel free to move it)
Thanks
Steve
Steve: I think you may be overemphasizing the stability issue. Both types of trailers are very stable if loaded and balanced and TOWED correctly.
Consider this:
A fifth wheel trailer:
Has a much higher profile making it more susceptable to side winds and head winds. There is a lot more sail there than with the average Bumper pull TT of the same size.
Is heavier than the same size bumper pull due to its additional steel needed for it's step frame.
You lose your truck bed (As has been mentioned by others)
You MUST buy an expensive fifth wheel for your truck. NO such hardware is required or even necessary for the bumper pull. Now I know there are those that say you need all kinds of expensive anti sway apparatus; the truth is you don;t. I have pulled my 33 foot TT 22 thousand miles in the last 11 months which includes two trips to Alaska. In the last two years I have pulled it well over 30k miles. I have never in any weather conditions needed anything like a WD or Anti sway system. It is HOW you DRIVE the trailer not the accessories that counts.
If your TV is properly sized for the trailer and most 250/2500 series HD with tow package will handle either just fine. My truck and trailer weigh a combined total of almost 17K. My truck sits level when hooked up and handles great.
What the decision really comes down to I think is the floorplan and the loss of your pick up bed. Stability isnt really a factor.
Good luck with whatever you decide and have fun.
About RV Newbies
