horton333
Apr 16, 2017Explorer
"To each their own, but a 5er is naturally more stable, simple physics. There is a reason that 5er don't need sway control devices."
As documented below considering the physics of the fifth wheel must have greater sway forces to both wind and torsional problems, that's why the manufacturers recommend at least twice as much weight forward (and so a much stronger truck) to compensate.
The other sway control method 5th wheels use is to move the pivot point to slightly forward of the rear wheels. This is highly effective at reducing sway but it dominates the use of the entire truck bed.
TT owners can use their bed, and buy a lot cheaper truck for the addition of some much cheaper sway control on the hitch itself.
About RV Newbies
