troubledwaters
Apr 17, 2017Nomad
rhagfo wrote:Very interesting conclusion. Totally blows away all previous held theories about what happens when the center of gravity is higher vs. lower.
While a TT is lower to the ground, and is not as tall as a 5er. I believe part of the reason that a 5er, is still very stable in a cross wind is the fact the hitch is as much as 2' to 2.5' higher than that of a TT, thus raising the point of rotation of the trailer. That would make the wind induced tipping force on a 5er less than the entire side of the 5er, where with a TT the hitch is on the same level as the bottom of the side wall so the entire side has wind induced tipping force. That said the driver of the 5er's TV, should also feel that force as a lateral more than a TT. I don't think this line of difference between lateral and tipping wind force would be a level line the length of the 5er rather run diagonally from the pin to the lower rear corner of the 5er.
About RV Newbies
