JoshuaH's avatar
JoshuaH
Question about having camper setup in near freezing temps.
We own a Forest River Wolf Pup 16BHS,
https://forestriverinc.com/rvs/travel-trailers/wolf-pup/16BHS/1330
My wife is an ER nurse at a local hospital, and she is currently living in the camper to have some isolation from myself and my 4 year old son. She works the night shift so her routine is to come home about 730-8am shower then go straight to bed and sleep in the camper during the day.
Tonight it is supposed to get down to 30 degrees, and a few more nights in the forecast for lows of 32 and 33.
My question is, if I disconnect the water supply, and bleed off pressure, leave the heat on inside the camper, will this be safe? This camper has low point drains, these obviously will not receive any heat, so I'm worried about those freezing, however my thought was if there was no pressure on the lines and the temp only slightly below freezing maybe that would be OK?
Next question, if my above plan is OK, will it be OK to leave the water heater on, it will be full of water, just no water pressure in the system. I'd like to leave it on so when my wife does get home she can take a shower right away and go to sleep as she works usually 12.5-13 hour shifts and needs to get to work as soon as possible.
I know there are ways to permanently heat your water supply to prevent freezing, but I was hoping to avoid that as I doubt we will have many more nights this spring that get below freezing (Central Missouri), and I sure hope we are past this Pandemic by next winter!
Any thoughts?
