mlts22
Aug 12, 2013Explorer II
Second Chance wrote:
Not counting the Westfalia VW pop-top in the '70s, my wife and I just purchased our first "hard-sided" RV (had a Coleman PUP for a while). Based on our location on the Savannah River in SC, I have some questions related to when the TT is not in use (stored at the house). Our summer days are typically in the upper 90s to lower 90s - but I have seen 107 and above on my personal weather station at the house. Our AVERAGE low temp in January is around 33 - but it can get into the teens with cold fronts. The trailer is a 2013 Surveyor Sport 200 by Forest River. My questions:
1. What types of things do or do not do well left in the trailer during the hot months? I'm thinking of things like toiletries, a few cleaning supplies, perhaps some non-perishable food items. How about soft goods like towels and linens. (I know to empty and turn of the frig and prop the doors open for air circulation.)
2. To what extent do you winterize your water systems and do you "blow it" or use antifreeze?
3. I have the option of leaving the trailer plugged in with the battery on board or pulling the battery and storing it in the garage (the latter being more work). If I have a reminder to check the electrolyte levels monthly, is it OK to leave everything plugged in?
4. Anything else you can think of?
Thanks!
Rob
1: TP, linens, and bedding stay. All food goes. The heat does a number on anything.
2: I use an air compressor at 30PSI, blow the lines, moving faucet to faucet to the toilet, making sure the water heater is drained, anode replaced, and bypassed. Then, I pump some cheap vodka in the lines and blow the lines dry again. Low-hanging areas are then protected because of the ethanol in case the temperature gets into the teens (worst case.) Traps and drains get RV antifreeze.
3: I'd consider pulling the battery, leaving it in the garage hooked up to a Battery Minder (trickle charger/desulfater) so it is ready for the next season.
4: Yes, mice and rats. Also, check the roof caulking seals. One cracked seal can turn your rig's value into scrap in just a few months.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
