wannavolunteerF
Aug 13, 2013Explorer
1. As soon as I arrive home, I wash linens and then replace in TT. Food is dependent on how long it will be before I go again. Some stays regularly however, I do try to rotate with what is in house. spices are the things that I have found the heat affects most.
2. First year I used pink stuff, last year I drained good and turned heat on low on the nights we were to get below freezing with cabinet doors open. I am a bit south of you and felt like the pink stuff smell stayed in the lines forever.
3. I stay plugged in almost all the time, I just check battery periodically.
I generally leave vents open (with vent covers) and use damp rid all the time. $2 containers are cheap way to manage moisture. I do park in my yard, so it is easy to go out and check on things. I also try to open doors and let fresh air circulate through regularly.
4. I have been lucky and not had a mouse problem (yet), but I did go through the trailer carefully looking for anywhere I could see light seeping through and fill with Great Stuff flexible..
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
