bsinmich
Aug 01, 2013Explorer
Not all RVs are built the same way. The cheaper ones have less insulation while some of the higher priced ones get more insulation. You could be looking at a 20# propane tank every other night. Bales of straw around the edges give a little more help than aluminum skirting. Unless you get dual pane windows (slim chance) you are going to have condensation and need the dehumidifier a lot. If water and holding tanks are outside they will freeze!! That is where they usually are on TTs.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
