wbwood
Mar 29, 2014Explorer
LarryJM wrote:Kit Carson wrote:eluwak wrote:Me, too.kellertx5er wrote:the bear II wrote:
Leave the grey water valve open and the blackwater valve closed.
DO NOT leave the grey water valve open. You'll need the grey water to flush the line after you dump the black tank.
My grey water tank fills daily... I just shut it the day before we leave an we're good to go :)
Yep I do the same:)
Larry
Not me...leave both closed all the time except when dumping. Don't want to take the chance of the sewer system backing up and into my motorhome. Or to have sewer flie up in my tank. Takes only a minute or two to go out and pull the lever. I'm normally out and about around the outside of the camper every day as it is. Just pull the lever and go walk around the camper and check to make sure everything is ok. By the time you make it around, it's probably finished dumping.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
