tex_wardfan
May 28, 2016Explorer
Robert_B wrote:
Every cable end connector was loose from the factory. I had to redo them all to get a signal through to the TV.
Run your cable from the CG box through a window and directly into the back on the TV. If it works, that tells you if it's a problem inside.
Also, my TV has a NTSC digital tuner (not a QAM digital tuner). At some campgrounds, I can't receive anything because the signal from the cable provided requires a QAM tuner.
Great idea. I need to try that.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
