mbutts
Mar 24, 2016Explorer
Cable TV not working, Antenna working
Hi,
I've used the cable connection successfully in my TT approx. three times in the past three seasons. At our first outing this year, the channel scan would run for 10-15 minutes, then only show really snowy images without audio on a single channel.
All connections were verified to be connected and the KOA worker verified there was a cable signal at the box.
Here's the six combinations I tried:
Television set to Antenna, TT antenna switch set to CABLE, ANT, or OFF. After a new channel scan, receives 5 local over-the-air stations.
Television set to Cable, TT antenna switch set to CABLE, ANT, or OFF. After a new channel scan, snowy, fuzzy image on a single channel.
Any diagnostic suggestions?
