MNtundraRet
Mar 24, 2016Navigator
Do as Roy said and connect a separate coaxial cable to outside park box and then directly to your television coaxial cable input connection. I call it "plan B".
We have found some parks do not work while using the MH's normal cable connection on outside of unit. It might also be caused by a newer television set. Most likely not a problem with the normal cable routing unless you messed with it.
If "plan A" fails, "plan B" has always worked.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
Related Content
- Feb 01, 2026Community Alumni
