Helimech
Sep 07, 2018Explorer
The electric current generated by a battery is produced when a connection is made between its positive and negative terminals. When the terminals are connected, a chemical reaction is initiated that generates electrons to supply the current of the battery. Lowering the temperature causes chemical reactions to proceed more slowly, so if a battery is used at a low temperature, then less current is produced than at a higher temperature. As the batteries run down they quickly reach the point where they cannot deliver enough current to keep up with the demand. If the battery is warmed up again it will operate normally.
You also need to Pee more when it is cold.:B
About RV Newbies
4,030 PostsLatest Activity: Jul 16, 2025
